I bought my 944 S2 in late April with approximately 85.5k miles on it. I have since covered about 2k miles and I got the 'Engine oil' light on when I started it on Saturday night. When I checked it on Sunday the level was above the bottom marker on the dipstick, but not by much. Therefore, since I have absolutely no idea what oil is in there at the moment I went and bought some 10w40 Magnatec to top it up. This has cured the 'Engine oil' light issue. However, a number of questions spring to mind:
Graham
- Is it alright to mix oils? What would be the consequences of mixing oils? I think that given I don't know what is already in there, perhaps I should do a full oil-change myself, then I would be topping up with the same type/grade as is already in there.
- Given that it seems to be burning/losing oil at the rate of 0.5l/1000miles is it really worth putting fully synthetic oil in?
- Is this rate of loss of oil unusually high (I notice that the handbook talks of oil consumption of up to 1.5l/100km)?
- Given that this is my daily driver and tends to get used for relatively short journeys (i.e about 9 miles in each direct to and from work) what spec oil should I be using?
- If I am burning oil, rather than leaking it (I don't think I have seen oil on the drive, but then normally when I am at home my car is over that patch!) is there anything that I can do about that?
Graham
