appletonn
Having popped into Unit 11 early this morning to get my car's suspension raised fractionally (6mm in the end) as at the RS ride height, I just felt it was proving too low for bumpy B roads and had also been advised that the dampers needed slightly higher ride heights to work effectively, I have learnt something new once more!
For all of you KW v3 converts, it turns out that the pitch of the threads on the damper bodies (that the spring platforms sit on) is 2mm, so for each 360 turn of the lower spring platform, you are raising (or lowering) the car by 2mm - makes it relatively easy to calculate how low or high you are going, should you be adjusting them!
