anti roll bar bushes
- Thread starter silver7
Richard Dawson
When I ran BMW M5s I changed the track control arm bushes for poly bushes (grunt from Australia believe it or not) which were cheaper than std and were no harsher. They made a big difference in that application to the turn in , braking and were more reliable.
Worth checking the "solidness" of the replacements as some polyurethne is harder than other!
I would certainly be interested to hear how you find the difference on RS.
Kind regards
silver7
paul howells
I have competed with my car for many years on standard ones.The cup cars had the same bushes,only the rsr/gt2r was polyurethane mainly because the whole of the suspension was sold mounted and uniball etc.
paul howells
sounds all standard rs stuff apart from the eng & box mounts and makes no real diff .
Some cup cars run the very noisy solid gearbox mounts also,this then helped keep the engine and box more stable on lift off of the throttle,and also helped to keep the gearbox in the right place while changing gear into and outoff corners etc
The rsr and gt2 also run the solid rear sub frame mounts
