I have purchased some turbo M030 ARB's to go on my 1984 lux and I was having a look underneath at all the bushes etc too see what I would need to fit them. I was looking at the bracket that the front ARB inner mounts attatch too and they flex quite a bit when you apply force to the ARB in the right direction. I couldnt decide if they were likely to be subject to any forces that would make them flex when the car is driving and was wondering if it is worth stiffening them before I put the larger ARB's on. On my car they are simple an L shaped metal bar with an indentation which I presume is to make them a little stiffer, not that it seems to work that well, I though welding a triangular bit of metal onto the L would do the trick.
Is it worth fitting poly bushes rather than OEM ones?
Tom
Tom
