pauljmcnulty
Am I right in thinking that, as long as it's suitable for alloy angines, there's nothing desperately special about the antifreeze the 944 needs?
ORIGINAL: pauljmcnulty
Nice to see the Assistant Reg Sec and me are both here to help at 08.15 on a Sunday!! What service.....
Actually I was printing off my entry form for the Cotswold Rally on 22nd April. Geoff informs me the 944 Register is looking favourite to win the trophy on entries received so far
ORIGINAL: robwright
As long as it is suitable for aluminium engines it should be ok. You need at least 50% antifreeze so you need to check what you have in with a hydrometer and hope you have enough spare capacity to get enough antifreeze in. As you should change coolant every two years you may as well start a fresh. Personally I change mine every year before the cold spell. Mind you I do have 3000 litres of it at work []
ORIGINAL: robwright
OK this is my method and I stress mine. Jack the front end and remove the undertray for access. Identify the bottom radiator hose so you know what to remove. There is a drain point on the rad but it can be a bit hit and miss or you may not be able to remove it at all. The bottom hose works every time. Get the engine hot so that the thermostat is open then you need to move fast lol. By draining hot you can ensure you get it all and you don't have coolant left in the block. Then remove the bottom rad hose followed by the header tank cap. Be warned the coolant is hot so be careful and you will inevitably make some degree of mess. Once drained reattach and secure bottom hose. No need to flush unless you have a specific need to. Premix the antifreeze so you can ensure that every drop you put in is correct concentration. Don't guess how much coolant you think is going to go back in then half it and hope your calculations are correct [] Crack the 12mm bleed screw on the top of the block and turn the heater to full heat. Fill from the header tank till coolant runs from the bleed screw. Rather than me explain the whole bleeding debarkle, which can be a mission in itself there are some good guides on www.clarks-garage.com garage workshop manual section. Once bled reattach the undertray and lower the car. Be warned bleeding may take some time and can be quite tricky on our cars. My tip is to run the engine at revs 2500 rpm or there abouts to get the coolant flowing well round the system. I do this by hand at the throttle body whilst observing the bleed screw. When a good stream is coming out at revs I then close the bleed screw.
ORIGINAL: zcacogp
Why the need to change the anti-freeze every 2 years? I've never heard that one before. Does it lose the capability to stop the water from freezing?
Interesting, thanks.ORIGINAL: sawood12
Anti-freeze also acts as an anti-corrosion element. You have alot of dis-similar metals in contact with eachother within an engine so lots of corrosion. That corrosion finds its way into the water (in the form of small oxidised particles and gets circulated around the engine promoting more corrosion (all that sludge you get in the coolant if you don't change it frequently), therefore by frequently changing the coolant you are flushing out the corrosive elements in the water and refreshing the corrosion protection by adding new coolant.
