Bow Runner
My LUX is experiencing an occasional stutter when running on low revs. It only happens when the engine is warm.
I have replaced the following but it still happens:
In-tank fuel filter (Porsche OEM)
Fuel line fuel filter (Porsche OEM)
Fuel pump (Bosch)
Coil (Bosch)
Distributor Cap (Bosch)
Rotor Arm (Bosch)
HT Leads (BERU)
Spark Plugs (Not sure)
I have also had the following done but again no solution:
Injectors ASNU cleaned
Throttle Body Cleaned
Checked the AFM and adjusted the arm to realign the track
It starts fine, runs really well and pulls hard. I have no problems over its performance but this blipping is annoying.
Any ideas would be really welcome.
other clues are that a phishing sound can be heard under the bonnet when it does it. You can also sort of hear a click under the dashboard.
Fuel pump (Bosch)
Coil (Bosch)
Rotor Arm (Bosch)
HT Leads (BERU)
