Anybody know where to get gutter rubber trims/seals ?
trackm3
As above, also how do you remove them and refit ? ive not looked yet so may be straight forward ?
M
Buy from OPC. Remove the delicate extruded alloy trim by locating the spring steel clips and pushing down with a strong thin bladed implement like a decorators scraper or such, teasing the trim off the spring clips as you go. Slide the old seal out of the trim and the new one in (be careful to check orientation) then push the trim back on to the spring clips.
Not as easy as it sounds though, new rubbers are circa £50 brick from OPC, there are around 6 clips each side that act like a barb to hold the trim down, you have to push the holding barb down to release.
Start from the back and stick something plastic in like a used credit card slide along until you find one then push down vertically and at the same time putting a little pressure on the trim outwards until it releases, you will find some of the retaining clips knackered, available from OPC for a quid or so.
the roof rubbers
944 559 707 00
£17 each from your local Porsche centre
replacement clips
999 591 732 02 @ £0.86 each pet lists 12
