Anyone fitted a USB charging port?
craiginuk
Hi, was thinking of using one of the switch blanks around gear consol for a usb charging port. Has anyone done this? Pics? And where can i get the usb/transformer gubbins. Would ideally like it to come on with ignition.
Craig
That's a good idea. You can buy a spare blank to test with. I have little usb charger that plugs into the lighter and it looks pretty good, black and around the same size as the lighter, it goes more or less unnoticed.
The best way of doing it would be with a USB extension lead in the blank plugged into a cigarette lighter charger behind the dash.
I have a very long charge cable for my GoPro mounted to the rollcage it ends up behind the centre console plugged into a 1Ah charger that is itself plugged into a 12v lighter socket I got from Maplins. That plugs into an ignition switched live and jobs a good 'un.
Buy more blanks than you need though, the actual space between the strengthening ribs is quite tight - I relocated my electric mirror switch into a blank and the first two snapped on me whilst drilling and filing.
I did exactly that - USB charging socket in the spare switch space
I just took a car usb charger apart, soldered suitable wires on and connected them to the cigar lighter supply ( the current draw from them is very low) I drilled and cut the blanking plate as the pics show and although it did stay in place on its own I did use a little epoxy glue to make sure.
Very clever and good craftsmanship- interesting to see what is actually inside those lighter plugs! Since mine had an aftermarket stereo, I just upgraded to one with a usb socket on the front....
Put it in the S2 but never wired it up there, but had it in the 2.7 for 3 years or so.
But would recommend getting a good shielded wire to do the supply, as I sometimes had interference on the radio.
