Anyone moved a Hard Top Fixing Kit onto another Boxster?
- Thread starter Guest
Black80XSA
Fold the roof completely. Then remove the carpeted panel adjacent to the seat belt - there is a small crosss headed screw near the base - feel for it in the carpet pile. You will also need to slacken a brass coloured allen bolt at the corner of the roll bar (near where the seat belt anchor is - this allows the another plastic section to be moved aside.
Now you need to put the softtop into a position with the leading edge about 6 inches from the header rail. Recline the seat on the side you are working on forward out of the way. Carefully move the fabric side panel on the inside of the roof towards the rear - its held by an elasticated strap - You will be able to see the head of the spinlock retaining bolt - its dark grey in colour, about 12mm diameter with a 5mm allen key recess in it.
You can remove the bolt, but there is a real danger of losing it - for installation, people wrap the bolt and the allen key in a plastic food bag to keep them together, and then when the bolt is nearly home, tear away the thin bag, and tighten the final couple of turns.
You will not be able to do this, so you need to find some way of ensuring the allen key and bolt cannot separate - quick set glue ???
Given that i paid about £30 for my set it'd say its not worth the hassle - the only real benefit you will get from removing them is the practice for reinstallation
Tool Pants
non Club member but v. knowledgable
Black80XSA
David
Got the top on now and it makes such a real difference!!
Thanks for your help on this David.
Black80XSA
You should notice much less windnoise now. You may have to make some fine adjustments to the fitting, there are adjustment screws located behind the triangular shaped sections on either side by the locking levers. I haven't had to adjust mine but one lever is tight when clamping down.
