Got an odd one for you...
Since I got it over 2 years ago, my car whistles from around the throttle body on light acceleration from 2000-4000rpm. There is no vacuum leak (confirmed by attaching a gauge to one of the vacuum hoses on engine side of throttle body and also, (with the engine off), the hissing sound of air when one of the vacuum tubes is disconnected after the car has been sitting overnight).
The whistle goes if I apply full throttle. I can even hear it when I open the engine cover and blip the throttle just lightly. I cleaned out the idle control valve today, but the whistle is still there. I have checked all the engine breather hoses & sprayed carb cleaner around every joint in the induction system repeatedly, with no effect on the idle speed, so I don't think this is an induction/vacuum leak. I even took my motorsound cover off & put the original one on, but no improvement.
Seems that a few cars have this problem going by what I've seen on the internet forums... a whistling throttle body.
Has anyone found a solution? It's driving me mad. [
By the way, my car's a 1994 normally-aspirated non-varioram, 107,000 miles & drives beautifully otherwise.
Thanks,
Roddy
Thanks,
Roddy
