sawood12
I thought i'd take the plunge and give Rainex a whirl.  I applied it on the windscreen of my 944 and Focus and my 944 hatch.  I does work.  The rain collects in very small water droplets that you can see beyond quite well even at night, and when you get going the droplets run off the windscreen like water droplets off a ducks back leaving very thin tracer streaks that don't impair your visibility.  In fact you can practically do without using your windscreen wipers at dual carridgeway speeds in light rain.  I do have one issue with it though - when you do use your winscreen wipers it seems to have made the windscreen quite tacky and the wipers judder accross the screen.  I cringe to think at the shocks being sent through my wiper mechanism due to the juddering.  I also get this juddering on my Focus as well, though not as severe.
Has anyone else used Rainex? If so have you had the same experiences as me? Have I applied too much?
Update on the flat blade wiper setup - I posted a while back that I was deermined to replace my wiper blades with a pair of the more modern ones . I have tried an interim step by getting some flat blade wipers blades that fit to the standard wiper arms. These do work OK. I had some initial problems with them but the seem to have settled in. However I have now taken the plunge and bought the drivers side arm off a VW Lupo GTi. There was a VW Corrado in the car park at work with the Lupo GTi wipers on them and they do look very good. Thanks to the side mounting of the blade onto the arm instead of the top mounting on the 944 arm, the wiper arm fits very neatly paralell to the blade and no taller than the blade iteslf, so the whole arrangement has a very low profile and hugs the windscreen barely half an inch off it's surface. Having bought one and offered it up to the existing wipers I can say I think this will work. I think you'll need two drivers side wiper arms as the longer Lupo passenger arm will be too long, however although the arm is about 1 inch longer than the 944 arms I think the wipers will fit on the windscreen nicely. The passenger side wiper blade tip will get very close to the edge of the windscreen when parked, but there is more than enough height in the screen to accommodate. I'll post pics when i've got round to installing them. I'm hoping that when installed they will have a much lower profile (which they look like they will) than the standard arms, create less noise at speed and generally work and look better.
