Anyone want to get rid of an old turntable?
- Thread starter edh
vitesse
My Hi-Fi is all vintage-ie, Leak Stereo 30+ & have just acquired(ie given) a Leak Delta 70 amplifier from a good friend on here-David Bladon-which will match my Leak Delta tuner,Akai cassette deck,modern Cambridge CD player-cost more than the rest on its own & 2 pairs of Wharfedale speakers-1 set in each room.
My record deck is a Goldring Lenco GL75 transcription deck with elliptical diamond pickups-2 Goldring shells & needle-1 Ortofon shell & needle-this is mounted on a spring loaded base & I got this free from a building site so it replaced my original Goldring Lenco GL 69 CHASSIS mounted deck which used to fit on a cabinet I made in 1969.
(My wife bought me a vertical Hi-Fi cabinet so the other had to go,sadly)
So the point of this long winded post is to say the GL 69 (no quips please!) is available but would need a plinth & a cartridge shell-it has the standard plug in arm fixture-i still have all the technical stuff & spares can still be bought.
However you may want a ready to use item.
Fred Hindle
Cheers,
38F3E1
Lucky I kept my old amp and deck and recomissioned my vinyl collection last year. They even have a vinyl shop where I live plus get the travelling collectors shows. Some of the prices of old vinyl makes air cooled Porsches seem good value :- 0
vitesse
Recently bought a Milty Duopad & fluid to redo my collection.
Can get quite intoxicating even before hearing the music!
edh
ORIGINAL: Fred Hindle
Usual place to look is ebay. I bet the most difficult thing to find will be a replacement stilus
Cheers,
Remarkably, that seems to be no problem at all. Interesting that some of the decks from the Pre-LP12 era have quite a following now.
tallmat
The sound is gorgeous. I love the way it takes around a minute to crank up to 33rpm, the damping of the arm, and the tactile quality. So does my 10 year old son who bought his first vinyl with his HMV gift voucher (xmas pressy).
Buying the new stylus took some research as the original Shure can be obtained (at high cost) from Japan. But then found a guy in Blackpool who holds stock of high quality alternatives. It sounds fine.
The 'service' involved thorough and careful cleaning ariound the motor and lubricating by sparing application of sewing machine oil (nothing else will do, say the hifi forums!).
Somewhat staggered to see only one on eBay and priced at $1200. I paid £50 (second hand) for mine in 1985.
Almost as good value appreciation as my 993!
vitesse
Technical & General,PO Box 53,Crowborough,East Sussex,TN6 2BY--01892 654534
edh
not often seen on this forum any more - I think he's busy running http://www.decoaudio.com/ and his 944's still broken, so I'd encourage you all to buy stuff from him []
