edh
I'm after a quick favour - I'd like to check that a reading I get on my AFM harness is correct. I've had some MAF (Vitesse MAF) problems & want to be sure that this isn't the cause.
There is a 5 pin connector going to the AFM - on mine I get a strange reading on the green/red wire. This is pin 4 of 5 (counting the empty pin as pin 1)
With the ignition on, I get a small initial voltage on that line which then drops to zero. The longer the ignition is on before I test, the higher the voltage is - I saw up to 0.1V
I guess this might be the same for all 944's, not just the Turbos as they all use similar AFM/ DME setups
Ed
Ed
