Anything I should do while the dash is off?
dunc
Just removed the dash on my 944 '87 turbo to fix a wiring fault, are there any others jobs worth doing while it's off?
Cheers,
Dunc.
I'd highly recommend buying and fitting 3x LEDs to improve the illumination of the instrument panel, also scraping off the old silver reflector paint and using silver foil to direct the light. Trouble is, I can't remember the ones I bought off eBay that are can bus error free (or something like that) to allow them to be dimmable. There was a thread on here at the back end of last year I think it was, with photos, explaining the job. Nice and easy and well worth it.
Change the little cog on the odometer if it hasn't been done recently there are a number of posts on how to do it.
Check over the heater controls for cracked cranks and things that may need lubing....much easier now.
I'd also check the linkage and bar that connects the pedal box and the master cylinder and check the operation of the clutch cylinder
A few more jobs to add to my list when I get the car back from the cage install!.. Timely thread for me [8|]
Massive thanks for the suggestions guys, all taken into account and dash back together now. Left the clock bulbs till another time (since they are easy enough to remove and I need to order) and the speedo gears have already been done.
Cheers :)
Dunc.
