Hi.
My car is a 2015 Cayman GT4 has 12k miles and is presently at an OPC due to the rear dampers leaking and the fact that the o/s/r wheel is rubbing against the wheel arch!
I am keen for them to change the dampers but they say the shock absorbers are not covered under the porsche approved warranty!
The warranty however states that this is not covered where the cause is ageing or wear and tear. At 12,000 miles I wouldn't class this as a premature mechanical failure and not wear and tear and I have some experience in these matters having spent many years working for all the major warranty companies.
Sadly I am not overly confident that the OPC will properly plead my case to Porsche Approved Warranty.
Has anyone had a similar situation? How did you overcome it? What worked?
Thanks in advance for any help you can provide.
