Are wipers meant to be that bad?
- Thread starter Guest
sawood12
http://www.autobulbsdirect.co.uk/home.php
But a few days ago I drove another P reg (but ordinary) car in the rain and Toyota's wipers seem to be able to clean the screen[8|].
The 993's wipers just don't seem to fit the screen that well. Maybe the springs in the arms are worn out.
911sse
Turn out to be just as cheap as a motor factor and it was a good tip from someone.
They are a slightly different shape than off the peg Bosch items, 944 included.
Same for the Boxster, just replaced both of them.
ORIGINAL: sailor
Guys
I switched my wipers to park on the nearside, because I wanted a clear view of that glorious front end. Bonus was a perfect wipe pattern. But you should always use a proper windscreen cleaner after you have washed and dried the car.
JohnC
993turbo
John,
How did you make this switch? Easy?, or do you need to completely replace the mechanism?
