Ash tray removal question
pwebb
PCGB Admin
The ashtray won't close. As we keep loose change in it there it may be a coin jamming at the back. Does anyone know how to get the tray out? I've taken out the insert but can't see how the unit itself comes out.
For the Cayenne 955..
Remove the horseshoe trim around the radio, depress the little spring tabs to pop out the A/C control head (a 90 degree pick works really well, just insert and twist), then you will see (2) T20 torx screws to remove.
Hope that helps
