Just had my visit to local OPC for the 911 Health Clinic. Excellent service as always and the bacon rolls were very tasty.
On my way there and unusually given the OAT of 11 degrees, my Temperature Gauge failed when it reached 60 degrees indicated some 6.4 miles after leaving home. It recovered at 7.7 miles and that was it. Now this is fairly normal in the colder weather when the OAT is below 10 degrees but unusual in the summer. OPC Tester showed a 'blocked thermostat' but as I had had this changed and the engine temp sensor as well some time ago we discounted this and the third sugestion was the Tiptronic ATF Fluid temp sensor.
As I understand it this sensor is part of the coolant temp/ATF/Oil package which dictates the Tiptronic mapping when the engine is cold. Its aim is to keep the coolant circuit closed to warm up the engine and ATF quicker and adjusts gear shifs accordingly. I could of course be totally wrong.
At the time of the failure I was doing about 75mph anf the engine still cool. Could this sensor be the underlying cause of the problem I have had ever since owning the car (over 3 years)? I believe the sensor (Part No. 996 605 123 01) is readily accessible from underneath and only a few minutes to change with the part in the order of £70.
Expert advice please - has anybody else had similar problems traced to this sensor?
Many thanks
Many thanks
