Hi. Just reversed my 996 turbo out of the garage after being on trickle charge for the last couple of month, it has the mirror tilt option on the passenger door mirror when put into reverse, but noticed that it went into tilt when the ignition was switched on and stays on tilted position when driving. It only returns to normal position when the the alarm is switched on. Any ideas anyone. Thanks
Auto door mirror
- Thread starter DerekBell
Try clearing the memory and resetting the memory function? Shot in the dark.....
Hi tried a fault checker and its not showing as a fault. But have noticed that the reverse lights are on constantly so suspect a sticking reverse light switch. Anyone any ideas of where the reverse light switch is located on a 6 speed manual right hand drive car. Thanks
