Auto gearbox not shifting properly
Antontsar
Hello,
My Tiptronic struggles to change up to 4th - sporadic at best. Luckilly when I select the manual mode, I can work up and down perfectly.
Before succumbing to the help of a mechanic, does anybody out there have any thoughts as to what the cause and the cure might be?
Nicholas
When was your gearbox fluid last changed? The tip on my 968 was a little reluctant at times, and much improved once I changed the fluid. It changes up and down just fine now.
Maybe you are simply driving the car enthusiastically, causing the gearbox computer to select a sporty program which will be reluctant to change up to 4th even when you ease off the gas.
Martin
