Auto to manual
- Thread starter angry
random hero
ORIGINAL: 944turboS
The change will cost a lot more than the effort is worth, just sell the car & buy a manual.
Good advice!!
Andy Duncan
Is the car LHD or RHD? Because hydraulic clutch configuration is different.
1. the transmission tunnel metalwork around the gear lever is different.
2. you will need a clutch pedal (pedals come in at least two variants).
3. You will need to make a hole in the bulkhead for the clutch master cylinder
4. the Auto brake pedal is different also, so you will need a brake pedal with the associated fixings
5. Ignition wiring is different as there is a cutout switch on the auto (Wiring diagram needed to reconfigure ignition switch wiring).
I'll post any other things I remember later.
Generally it can be done but its a lot of work.
My knowledge is based on building an 944S2 racecar using an ex Jap 944 Auto shell.
Andy Duncan
