Just a quick note to see if there is anyone else out their that has experienced anything similar to this. Picked up my first 928 S2 (childhood dream) last Friday in Arbroath. Everything appeard good regards engine bodywork etc. The dissapointment occoured on the trip back to London when after 200 miles the transmission failed as I attempted to accelerate after hitting traffic on the M6 arount Knutsford. I limped into Knutsford Service Station & re-started the car & the automatic gearbox (4 speed) apperaed to be functioning correctly again so I pushed on, only to have transmission failure again 10 miles south (engine reves but absolute pitiful power via the auto box). I limped into Sandbach & the AA were called. They checked the ATF fluid level with Nutral selected & engine in idle & this was ok . Their diagnosis was put it on a relay truck back to London. So its now in a Automatic Transmission Garage awiting its slot on the ramp. Initial discussions with the garage owner have indicated that it could be a desintegrating clutch plate causing the filter to progressivly block up. He said that once the sump has been removed & an inspection of the fluid can be conducted he will be able to verify this as a disintegrating clutch plate looks like tea leaves in the fluid. I'm no expert at all regarding automatic gearboxes & would value anyone elses experience of similar failures.
Thanks - Ken.
Thanks - Ken.
