Avatar's !!!!
- Thread starter 2fast4u
John H
johnh@arthurlea.com
Fred Hindle
Check size - Image / Attributes
You will see the size of the file in bytes and the Width and Height.
Change the width and height by the same ratio to keep the picture the same shape.
As a rough guide, if the size of the picture is 400 bytes and you need to to be 200 bytes
then divide both figures by 50%. You will probably have to do some experimenting until it
is below the allowed limit.
Do a Save As with the word small added to the original picture so that you don't overwrite it.
Load the picture into MSPaint again and check the image size - if you don't do this then the attributes aren't shown correctly.
When loading the avatar onto the forum remember to click Apply
Any problems email the picture to me at fredhindle@i.am and I'll have a play with it for you.
2fast4u
I think I should dye my hair blonde........how you getting on Brian? It's like being back at school and struggling with the homework!
Kx
Fred Hindle
Send me the picture and I'll try and create some instructions for you using that picture as an example. Then you should be able to do it in the future.
Cheers,
LBD
ORIGINAL: 2fast4u
That only gets you so far Kim!
2fast4u
ORIGINAL: LBD
ORIGINAL: 2fast4u
You will need to tell me how far next Thursday!!!!!!![
2fast4u
ORIGINAL: gordon
This sounds the the Porschaforum club[8D][8D][8D]
Sounds like you're getting a bit hot under the collar Gordon
