Back Box Heat Shield - Part Number?
- Thread starter scam75
Waylander
944 503 137 00 NLA, since 2014
and just to make it easier, they call it a guard plate
ECS In the USA say they have one
https://www.ecstuning.com/b-genuine-porsche-parts/heat-shield/94450313700/
Waylander
951 503 139 00 is for M249 Cars, and NLA
https://www.ebay.co.uk/itm/273629551954
scam75
Well-known member
I think this is the correct part, but no part number on the listing. To be fair it looks in reasonable order.
I just had this used rear exhaust heat shield delivered, not sure why it is in such good condition but I spotted a german seller "Schöner und Wolf" (possibly a breaker) listing a few of them. The part number on the listing is incorrect (for the fuel tank aluminium heat shield). It looked reasonably similar to the corroded piece of metal I removed from my car and on closer inspection there is a slight difference in the moulding but otherwise they look indentical size and the mounting points are in the same place.
![](http://i.imgur.com/y7kxMGLl.jpg)
![](http://i.imgur.com/pOfl1ECl.jpg)
Link to the seller below (no affiliation) -
https://www.ebay.co.uk/str/schoenerwolf?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=BEgoUUvvS6i&sssrc=3418065&ssuid=yhUDH9aGQba&widget_ver=artemis&media=COPY
scam75
Well-known member
Stuart
Mine is broken and rattling again. Did we ever get a definitive part number? It's definitely a 250 turbo specific part.
Two part numbers in the parts database, both NLA since 2014
95150313900 (MY 1989 only) - with option 249 (appears to be auto / tiptronic) (is this some mysterious automatic turbo?)
94450313700
Looks like the 951 part number is for automatic transmission only?!?! unless there is a mistake in the parts database. If so it would suggest (as I thought) that the heat shield is the same for all manual cars. This would make sense as the rear silencer is the same shape (and rough size) for all models. I think the turbo exhaust pipe is wider though but the back box itself is about the same size.
I suppose you could fabricate your own from some sheet metal or a friendly body shop?
There is only one option for the centre shield with a 951 part number (95150486900) but it doesn't say it is model specific
scam75
Well-known member
It's definitely NLA although I'm going to call Porsche for a laugh and see if they can at least help with the part number. It's also rocking horse poo 2nd hand.
Mine is not actually too bad, its only came away at the screw hole lug nearest the back corner of the chassis. I am going to drill a hole in it and tie wrap it tight for the time being (as it rattles around 1,200 rpm when pulling away, then its quiet) around the exhaust hanger. This worked before on my last one before more disintegration set in!
