CVN187Y
]Can anyone help....please...
I recently changed my head gasket on my 1980 Le Mans, connected everything back. Charged the battery.
I tried to start the car and the engine turned over very slowly, and there was some backfire from the exhuast. I presume its because its flooded with fuel.
The battery with a voltmeter reads 11.8V, there is half a tank of fuel, there is backfire from the exhuast and then engine turns over extremely slowly[X(].
I turn the headlights on, turn the key and the headlights dim. I recharge the battery still no luck. I then try to jump start the car again still no luck. I can hear the fuel sender near the rear wheel buzzing away, there is fuel coming out of the injectors. I then check all the earth leads and all ok.
Can anyone help? Please....
The car was running before I changed the head gasket.[&o]
