Giving up on the £450 944 so she's into my mechanics Tuesday for him to diagnose the starting issues.
If you haven't been following the restoration thread here's a quick summary>
Paid £450 for her 1985 square dash 2.5n/a she had been sat for around five years with various states of restoration, got her to do this years Scallyrally Millie Miglia in June.
So far replaced>
Spark plugs
Coil
Ht leads
Oil Filter
Fuel filter
Air filter
Fuel Rail
Battery
DME relay
New seats
Brakes overhauled
New Spax front springs
Alloys
Brake lines throughout(ongoing)
Braided hoses.
Basically she doesn't like to start from the key no end of turning over then she fires sometimes other times she runs the battery down.
Car will start on a tow start within a few feet. Will run on idle fine after adjusting the idle valve. Sometimes when she has been running she'll start straight after easy on the key other times she won't.
Done a flow test passed
Stripped the afm down and tested and done the later mod to add the bridging wire all passed.
Got spark.
Got voltage to the injectors.
DME test all passed.
Checked for vacuum leaks replaced hoses and jubilee clips.
Now the only things I can think of are crank sensor or temp sensor any ideas?
When cranking the rev counter bounces but sometimes doesn't which leads me too the crank sensor.
When she runs she runs fine for a car thats been sat for so long, did have a wavering idle but thats fine now.
Only place I can find the Crank sensor is Ebay USA is there anyone else?
So far replaced>
Spark plugs
Coil
Ht leads
Oil Filter
Fuel filter
Air filter
Fuel Rail
Battery
DME relay
New seats
Brakes overhauled
Alloys
Braided hoses.
Got spark.
