BAFFLING ??
- Thread starter Deleted User
Jinxy
pauljmcnulty
924nutter
924nutter
Take the key out of the ignition?ORIGINAL: pauljmcnulty ......... It's incredibly annoying to have a while to wait in the car and the fan running the whole time!
GlennS
I'm surprised you're surprised by this. It is a fairly common feature on cars. Out of my last 6 cars, the VW Golf is the only one that doesn't do this. Perhaps the difference is that being rather old your 944 fan has gotten a little noisier and thus is more noticeable.ORIGINAL: Jinxy That's even more baffling then because it only works when the key is in, so I would imagine you would be shortly driving afterwards & then there would be plenty of ventilation anyway ??? LOL i'll just add this to the other little quirks of the 944 design team think tank !
andy watson
Moderator
Then you wouldn't be able to listen to the radioORIGINAL: 924nutterTake the key out of the ignition?ORIGINAL: pauljmcnulty ......... It's incredibly annoying to have a while to wait in the car and the fan running the whole time!
ChasR
Unless you get a Becker or Blaupunkt Radio which can be turned on for an hour without no ignition supply. However, this may restrict your CD player choices admittedly [ORIGINAL: andy watsonThen you wouldn't be able to listen to the radioORIGINAL: 924nutterTake the key out of the ignition?ORIGINAL: pauljmcnulty ......... It's incredibly annoying to have a while to wait in the car and the fan running the whole time!
andy watson
Moderator
Plus you may fall asleep listening to the Archers! and then wish you had the fan noise to keep you awake!! [ORIGINAL: ChasRUnless you get a Becker or Blaupunkt Radio which can be turned on for an hour without no ignition supply. However, this may restrict your CD player choices admittedly [ORIGINAL: andy watsonThen you wouldn't be able to listen to the radioORIGINAL: 924nutterTake the key out of the ignition?ORIGINAL: pauljmcnulty ......... It's incredibly annoying to have a while to wait in the car and the fan running the whole time!].
924nutter
There's a raydee what now?ORIGINAL: andy watsonThen you wouldn't be able to listen to the radioORIGINAL: 924nutterTake the key out of the ignition?ORIGINAL: pauljmcnulty ......... It's incredibly annoying to have a while to wait in the car and the fan running the whole time!
