Whilst doing my PS pump seals I had the airbox and auxillary belts off so I though I'd pop off the balance & cam belt cover to checkout what lurked below.
I noticed that on the balance belt there is a lot of play on the long run from the lower adjuster up to the top balance shaft pully and reading the manual they use a special tool to measure the play on that section of the belt.
As my belt was moving some 20 - 25mm I thought best just nip it up a little until I can get it checked properly so tightened the lower adjuster enough to bring the tension to a more realistic level. I also checked the idler pully clearance which should be 0.5mm. Having done this I've noticed that the idler & or the adjuster pulleys hard to tell now make a "whirring noise" is this normal or have I got something adrift, is it just the bearing within the idlers are worn and need replacing ?
Mike
Mike
