Folks,
I've recently had my water pump replaced (at a Porsche indi) along with a full belts & roller kit.
On picking up the car from the garage I noted that it was whining, but I was assured that it was quite normal and would settle down with some time/miles. I had noted that the car whined a little before the belts were changed, but nothing like it is now - sounds like I have a super charger, something is clearly not quite right. A bit of internet research seems to point at the balance belt idler being incorrectly adjusted, contacting the belt and making the whining noise I'm hearing.
I'm going to be taking the car back, but before I do I'd appreciate any advice on offer so I'm cluded up when I speak with the mechanic. This is what the balance belt idler looks like - it's spinning constantly as is contacting the belt at the bottom (should be 0.5mm?). You'll also note that there is a big gap at the top, easy 5/6mm. I've read that spinning the roller 180 degrees might solve the issue?
Any advice gratefully received, cheers in advance!
