Balls of steel, brilliant
Apparently its a famous beast known as the race taxi...............
Below is translated from the Race Taxi web page...........
At present we are to be tested with the Race taxi in the test phase around chassis attitudes. For the optics (lacquer finish inside and outside) still no time was used. The current lacquer finish is only a rust protection. After conclusion of the test phase the vehicle is divided completely and laid on only then the final lacquer finish. Subsequently, the Race taxi is again developed. Let you surprise.
Technical data:
Type: VOLKSWAGEN T1 (Split Window) 1962
Engine: air-cooled light alloy six cylinder of Porsche (993 Bi turbo)
Capacity: 3.600 ccm
Achievement: Original 408 HP later approx.. 500 HP
Transmission: Mechanical six-gearbox type 996 GT3 with cable assembly.
Brake assembly: ventilated and punched disks, original Porsche 993 Bi turbo with ABS.
Chassis: in front and in the back independent suspension with elevatoradjustable shock struts.
Adjustable stabilizers.
Steering element: Power steering by Porsche (993 Bi turbo).
Wheels: Three-part BBS racing rims (8.5J x 18 in front and 10J x 18 in the back)
Weight: Approx.. 1600 kg.
I think these guys are the same as another clip I saw on Youtube. It was a mini van, stripped out with a Honda VTec engine vs. Sabine Schmidt in a 997C2S at the ring. Sabine only just beat it on the long straights where the Porsche had alot more grunt, on the twisty stuff the Mini was off into the distance.
