Batt dead unable to open bonnet
thevideovaults
Hi,
I think I read somewhere that there is a cable to release the bonnet under the wing ? I have tried to power through the fuse panel but no luck.
Any help would be much appreciated.
Nat.
fuse panel didn't work for me at first , are you using another car or a loose battery ? if so is that charged enough , i tried using a battery charger first off didnt work off that you need a good earth on the door lock catch wiggle it about not heard of many that don't to work , if all else fails phone the local OPC for advice that should be free
Rob
Thanks Rob,
Used a batt connected to another car with a long jump lead, got the alarm to go off but nothing else. Put the key in the door but nothing. Also tried to charge it but nothing.
Nat
See this thread - may be of help? Not turbo specific but I guess they are all the same
http://www.pistonheads.com/gassing/topic.asp?t=251278
