steveoz32
I don't use her often, so she was sat all week in the garage and then ran at the weekend. I did one long-ish run, followed by several short runs.
I went out this morning to start her and I am not happy with the turning over of the car. The battery is showing 12 volts before turning over, it drops drastically when cranking and all lights dim quite a bit on the dash. The car fires after two or three turns, but the battery doesn't seem to either A) be holding the charge or B) enough cranking amps to crank the car over that well.
The first time I fitted the battery I notice an improvement over the old, but again it's sluggish.
I popped the battery cover off today, and checked the battery specs, to my surprise it has the AH and CCA of an S4 battery, but the label clearly states s5?? I'm a little confused, so I called the place that supplied, and apparently the S range come in varying specs depending on application and it is not determined by the actual product family of the battery?
To say I am annoyed is a bit of an understatement, as I have not got what I paid for. As a result I am returning to the supplier for a full refund (I may as well of bought an S4 with the same rating for less cost).
I understand that I left it for a few days, but there is no way it should not be cranking as well after such a short time, and to add to that, it is not as advertised. I also popped the voltmeter on the terminals when the 996 was started to check the voltage again from the alternator and it is a solid 13.9 volts, so it is providing enough current to keep the battery topped up.
As a result, I'm not ordering a replacement from these guys! I called the OPC, and I have been advised that they recommend a minimum of 80AH although he couldn't tell me the CCA.They buy the MOLL unit in, and fill / charge themselves at a cost of aprox £180.00. That could explain why the lower rated Bosch I was supplied is not really up to the task. I've been reading up, and some people have recommended that the OEM MOLL battery not be used, as they have a lifespan of only a couple of years, and a lot of people opt to upgrade to a heavy duty exide battery.
With that in mind I have now found this:
http://www.battery2u.co.uk/Car-Batteries/Exide-Car-Batteries/Exide--110TE-
It's 85AH and 800CCA - quite a bit more than the 74AH and 680CCA I was supplied with.
I'm just checking with you guys that this should be ok - I have found a couple of sites that list it for the 996 but thought I would check as I'm hoping to get it right this time....
Cheers,
Cheers,
