Battery Changed and now have PSM and ABS Lights on
- Thread starter mj28127
Chris_in_the_UK
https://www.porscheclubgb.com/legacy/clientftp/Register/996/tec_effects_of_disconnecting_battery.pdf
Chris_in_the_UK
Gordon Attar
The Guru will be along shortly, no doubt, to tell you what you should be doing![]
I suspect that Gordon is correct, and it needs diagnosing/resetting with a Porsche tester. If you are near me, I'd be happy to do it for you. It coult be what Alan says - brake pedal switch is a favourite - but I think it unlikely that disconnecting the battery would cause it to play up. A diagnosic check would also show that, if it were the case.
