Hi,
Can anybody please confirm that the procedure for changing the battery on a Boxster 2002 3.2S is the same as for the 911, ie, drivers door open, key in and ignition on, leave door open, disconnect battery, install new battery and connect, open drivers door window all the way down then back up again to reset position, turn off ignition and key out - job done and alarm kept silent? Thanks.
Also is the alternator diode pack a DIY replacement job or best left to the experts?
