I recently found that my battery had run flat despite my taking the car out and running it in anger regularly - well that's what there for! I bought an automatic charger from my local Halfords which was a combined charger, but a maintenance charger also - according to the instructions, "designed to keep the battery at optimum charge on classic cars" etc..
The battery recharged without any problem and started on the button first time. However, the instructions also stated that if the battery was left in situ within the car, then you should disconnect the negative terminal whilst charging. This I had done.
What concerns me is that when reconnecting, the alarm went mental, so did the immobilser, althought they all settled down once I locked and unlocked the car a few times (a Thatcham cat 1 combined system with the central locking). What I can't get my head round though is if I am to leave the charger connected all the time just pulsing the battery when it detects a drop in voltage, surely I don't have to keep connecting and disconnecting the negative terminal every time I want to use the car??
Has anyone any experience of this situation, and is it safe to leave the charger connected without disconnecting the negative terminal everytime??
