thinking about buying a battery conditioner while car is in the garage for winter.should I disconnect the battery and leave the conditioner on or leave battery connected
Battery condition
- Thread starter Dave jones
Leave the battery connected. I have owned my 991.1 C2S from new (six years) and often have to leave it in the garage for up to a year and use a CTEK MXS 5.0 without a problem. Some connect the negative to the body but both of mine run to the battery and are permanently fixed. If you have a concern talk to your maintainer or OPC.
Your 991 will have the stop start function.
According to the CTEK website the one you should use is the 'CT5 Stop / Start' model
https://www.ctek.com/uk/p.../car/ct5-start-stop-uk
Or have I missed something?
Peter,
The battery is an AGM type (I assume Banner brand) so you just need one that is suitable for charging that type, the CTEK MXS 5.0 mentioned above is one and others models such as the CT5 Stop/Start you mention.
Thanks Ralph - its all marketing and all very confusing! But thank you.
Thanks Clive - mine is the AGM type. Thanks for the advice as always!
