Further to my separate thread on the subject of outdoor car covers, my car is now "under-cover" on the driveway! [
On the basis that I will probably use the car relatively infequently over the winter, due to salt on the roads etc, I require to research the subject of keeping the battery in peak condition. I purchased a new battery from Halfords, earlier this year, which came with a four year guarantee. Should I buy a battery conditioner which presumably needs to be connected to the mains to do its job, or a battery isolator to cut the supply.
I'm not particularly technically minded, so please excuse the following if I'm well off the mark. [&:]
The problem, as far as I can see, with the battery conditioner, is the fact that I'll need to plug it in at the house and have a lead stretched from a window to the battery - not ideal!
Similarly, I guess that the downside with an isolator is that it might mess around with the engine management etc when I reconnect the battery.
Am I anything like correct here? [8|]
Which is best?
Which is best?
