Battery Conditioner - recommends/suppliers?
- Thread starter day1zero
Fred Hindle
Optimate is probably one of the best ones around (about £40). can be wired directly to the battery terminals and has an inline connector so easily disconnected when not required.
Check this thread 'Setting up battery charger - help required ' in the 996 section.
Machine Mart / Halfords do ones which some people use of this forum, always seem to be good reports (about £10) if memory serves me correctly
Peter Morgan journalist and engineer who writes for 911 Porsche World sells his books and the best battery conditioner available, ie same as Porsche sell but using the manufacturer's brand name - Certek, model Multi XS 3600. I have two and swear by them. Peter Morgan's web site is; www.pmmbooks.com
Hanhams81
Fred Hindle
Not sure how waterproof the solar chargers are although putting them in clear plastic bags that can be sealed shouldn't effect their performance.
One of the major drawbacks to using them in this country is that they need sunshine to operate at their best.[
Cheers,
Neil_Pickard
Ex Club Member
sidned
I don't think the solar charger work on our cars. They sit on the dashboard or stick to the window with suckers, so weather isn't a problem. As I understand it, we cannot use them as they connect through the cigarette lighter, and as our lighter is not active when the ignition is off, there is no circuit to allow the battery to charge. I'm happy to be proved wrong, as I would like to use one of these but this is what I was told.
I suppose you can connect it straight to the battery, but that would involve poking wires through the firewall and having a permanent connection to the battery, or at least having to disconnect it every time you drive the car.
ORIGINAL: sidned
Oliver,
The 'solar' system is intended for some farm vehicles, and I would connect directly to the battery with crocodile clips, just to keep some juice in the system.
Connected my battery charger the other day (via the cigarette lighter) and noticed that when connected with the ignition off it did nothing (which we would expect), when connected with the ignition on it started charging (again which we would expect), but here's the odd one: connected with the ignition on then turned the ignition off and the charger indicator lights still showed it as charging [&:]
To be honest I cannot remember why I turned the ignition off.
I have not checked yet to see whether it was actually charging or whether the charger was just being a bit 'dim' and not really telling it straight. Only thing I can think is that there is perhaps a relay in the circuit (or something else - electrical priniciples was never my strong point) which holds the connection open if there is a voltage/current at the cigarette ligher, but this seems rather unlikely.
I dare say I will investigate more when I have a chance because it will save adding a connector direct to the battery.
