battery conditioner
- Thread starter richyrich
good product, good price. you need an adaptor for the ciggy lighter socket.
The easiest way I found to hook it up (if you have a garage) is to attach the (included) fly-lead with plug connector to the battery terminal nuts and then all you nned to do is reach into the bonnet to plug it in - no faffing around with crocodile clips on the battery.
If you don't want to close the bonnet on the lead but you do want to lock / alarm the car then press in the latch to the closed postion before you lower the bonnet, that way the alrm will not go off and your under-bonnet light will stay off. Just remember to pull the bonnet release / properly close the lid, before you drive off - it is all too easy to forget...
all the best
tim
ORIGINAL: tim993
I'm not sure if it's the same on your car, but on mine you can route the cable from the top of the bonnet - by the windscreen wipers. Then you can close the bonnet as normal - with the latch working.
Edit:
Maybe not - I realise I misread you as writing 996TT rather than 993...
all the best
tim
kitchens
