The_Taffinch
Hi All,
I have a bit of a dilema and hoping someone may have a bright idea![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have a '05 (Gen 2) 996 C4S and a couple of months ago I lost my remote key fob and now only have a physical key. I have been meaning to replace the remote but work has meant that I just haven't managed to get around to it.
Now the battery has gone flat and of course the electical bonnet release won't work. I have tried the procedure of using a donor 12V battery with the emergency release terminal post in the fuse box. The alarm sounds but the release lever (for either the bonnet or the engine compartment) do not operate. I have tried all sorts of combos of leaving the key in the door as some posts have suggested, unlocking/locking the door, and also turning the key in the ignition...all to no avail.
I have also tried to trickle charge the battery via the cigarette lighter but this has not worked. The charge process started but the charger now indicates a battery fault.
Can anyone suggest a means of getting access to the battery? A thousand thanks in advance for any suggestions?
