The maximum drain on the battery providing you have no accessories (aftermarket fitted) should be under 25miliamps, therefore there shouldn't be an issue with battery going flat or significantly reduced after just 5 days.
There are 1000 miliamps in an amp.
So 40 hrs to use an amp at 25 milliamp drain
Therefore If you have an 80 Amp hour battery you should be able to leave the car for 3200Hrs before the battery would be flat that's 133 days 8 hours, so if you are having a battery going flat in 5 days then there is a problem. OK that's theoretical and things very rarely work to theory.
Battery voltage is typically 12.6 to 13.3 volts but voltage alone is not the be all and end all so you should not be too concerned about it, however, to satisfy yourself that you don't have a current drain you need to borrow an Amp clamp meter and measure the drain, The amp clamp meter is a simple meter that has a "C" shaped claw head, you open the claw just like you would a set of pliers, they are spring loaded to close like an insects pincers over a cable, you don't need to tap into a cable or disconnect anything just place the claw over the positive lead from the battery - yes over the insulation - from that point any current running through the cable will be detected and will give you a reading.
Open the bonnet and let the car stand for at least 15 minutes locked before you measure as the car draws a little more power initially on lock up but shuts down standby components after 15 minutes - at this point take your reading - If its over 25 milliamps then something is drawing the power and you need to investigate what that is.
With the meter in place unlock the car and take note of the higher reading as the standby components will be reactivated and therefore a higher current draw, this now becomes your base measurement. (just the difference between the lowest reading and the now unlocked reading - add the difference to 25 milliamps and that is your target total draw)
Pull one fuse at a time and take note of the reading, keep doing this until you find the circuit that is responsible for drawing the extra power, once you have this its simply a matter of establishing what the fuse supplies.
One other thing to do is to disconnect the alternator connection and see if that reduces the draw, It shouldn't make one iota of difference but the alternator does have an habit of blowing one of the diode packs (there are three).
A diode allows current only in one direction and these are set to provide power away from the alternator, if a diode fails it allows current to drain to the alternator and in turn it tries to work like an electric motor but it cant turn because of the drive belt - so it draws quite a bit of power.
You may be able to get just a diode pack for the alternator but it is difficult, so a recon one off Ebay for £130 ish is perhaps the cheapest and easiest way to fix it
Sorry if this reply seems a bit teckie but I have tried to keep it simple
