Battery gone in key, needs recoding?
- Thread starter Guest
Helen Goff
No.1 Poster
i've replaced batteries in Boxster key fobs at least three times in the last 6 years with no probs
Black80XSA
penfold944
My spare key was doing the same and when i looked at it the microswitch that worked the main central locking was broken. It required a new dohickey and the OPC had to reprogram it
Helen Goff
No.1 Poster
ORIGINAL: Phil Mansfield
have checked with OPC, it needs the key recoding and shows 30 mins labour time! Anyone know how to code the key on a 2000 Boxster? Or do they have to use their computer to do it? (I know this is the case with the keyless cards for Renault as I work for them)
you are kidding[
first time the battery went on one of the keys on my 2000 Boxster i took it to the OPC and the service dest receptionist put a new battery in right in front of me using her nail file and charged me £3.50p
Not saying that is your problem, but it is worth noting
without the code from Porsche the dealer cannot acces the on board electronics to accept a new fob code
The fob unit has an embeded code in a ROM, it cannot loose its code even if it is left for years without power, it is not correct that the battery should be connected the wrong way round first, you will damage the unit.
Once the dealer has inputed the code from Porsche they program the car electronics to accept the signal code from the key fob.
If you have more than one fob and either add or replace one of them then all fob units held must be reprogrammed into the car at the same time.
New fob is £130 including the programming.
Had a new one today (16 Sept) from Autobahn Porsche
Glyn
