battery in boot?
- Thread starter pae
85.5 cars onward have it in the boot.
Must be a heck of a long cable as you say[]
pae
Anyway, just had a thought - could I gett some cheap jump leads to make a cable out of? I can't see why not, but perhaps they're not rated for continuous use or something technical like that (electrics are not my strong point!) Obviously I wouldn't attach the lead with the jumbo croc clips - my electrics aren't that bad [] []
You can find 200amp, 8mm multi-strand, 2.5 metre leads for not a lot on e-bay. would that do the job?
Fred Hindle
carlmthompson
I think AWG4 is what's fitted from the factory.
You can get this from Maplin Electronics http://www.maplin.co.uk/Module.aspx?ModuleNo=6208&criteria=Shark%20Installation&doy=29m5- they sell it for ICE installation, and it's a damn site better quality than the stuff put in at the factory. It comes in Black and Red, and you buy it by the 1/2 metre, so fill your boot(s) so to speak[]
You may also want to invest in some quick release terminals while your there, as the orignals from the factory are captive, so can't be re-used.
pae
BTW, it's for motorsport use. I'll be marshalling in a couple of weeks time so I think I'll grab a few minutes with the scrutineers when they've finished, just to check on anything else I need to consider.
Phil
carlmthompson
