lesworth
Has anyone experienced this before?
My car is stored in my garage and only used once a fortnight or so. A few weeks ago it turned over a bit slower than normal but fired OK. Its not connected to an optimiser / charger and I guess I expected a little drain due to the alarm immobiliser. I drove the car for a good 60 miles to ensure the battery was charged. A week later, the battery seemed completely flat. Other electrical items worked fine, just not enough juice to turn the starter over.
I attempted to charge the battery over 24 hours. When I tried it, nothing. I tried charging again for 12 hours. I tried it and it turned over a couple of times but then nothing. Third attempt at charging (this time with an Optimate) and again nothing.
I'm assuming the battery needs to be replaced (although it doesnt look that old). Tonight I will attempt to re-charge it after removing from the car to rule out any wiring / grounding problems. I'm also going to check the grounding points as per 101 Projects.
Does this sound the right approach? If its not the battery could it literally be any potential electrical problem causing a drain / lack of charging to the battery?
Thanks!
Thanks!
