hi, I wonder if you folks might be able to help please. I've got a 1998 Boxster 986 and I don't have a driveway or a garage (I live in London...). The car gets used fairly regularly, but these days, it only has to be undriven for a few days before I notice the battery is less than optimal > drained. The constant draining of the battery, charging, replacing etc is I fear, having a negative impact on the ECU - Both my Remote Key fobs have stopped working, which may or may not be related - either way, I'm guessing it's not good for the car.
I'm assuming there's an electrical drain somewhere that needs to be tracked down and fixed, but in the meantime, has anybody got any advice on how to keep the battery topped up, when I don't have access to a plug socket? I've tried the solar panel/cigarette lighter option, and it doesn't work - presumably because it only works when the socket is active and when the ignition is off and it's locked, it's not. I'm going to try connecting the solar panel directly to the battery and trail the wires under the passenger door, but sadly, local hooligans will quite likely feel it's a right laugh to yank those out for me. So I'm somewhat wary about that option.
Does anybody have the same issue, would love to hear your solutions. Many thanks.
