Flatty
advice please you 944 Guru's
I am still learning about these front engined jobbys but I suppose this question is simple to answer for those who have more experience.
My 944 race car has a little problem. It won't start from cold without jump leads(turns over slowish but doesn't fire). when it's warm it starts fine, when it's hot ( after a few hot laps the started won't turnover).
It is a blueprinted engine and as such it is pretty tight but I don't feel that is the issue.
The battery seems to take a charge and holds it quite well without load, but after 2-3 attempts at starting the volts are down to about 11v
Questions[8|]
Is the battery screwed or is the starter just taking too much current to turnover?
Is the starter serviceable, I have removed it and bench tested and the solenoid and motor operate fine.
Any help would be much appreciated before I go off and spend my pounds
Ta very much [
Questions[8|]
Ta very much [
