I'm having a problem with my battery going flat over a week or so with no use. I'm pretty sure the battery is ok although it's difficult to check as it's sealed. It does however accept a full charge with my optimate charger.
Does any one know roughly how many amps the car should pull when it's turned off. ?
As far as I'm aware, the only things that are still 'live' are the clock, immobiliser and stereo memory function. I've hooked up a meter, and pulled all the fuses and relays I can find, this hasn't turned anything up. The car is pulling between 1.6, and 3.2 amps with everything switched off. Anyone any ideas...?
