Hi,
My battery is on its final legs and is due to be replaced. Apart from going on-line and purchasing from a regular supplier does anyone have any recommendations for battery replacement ?
Also, and I'm not sure if its related, my 968 has intermittent starting problems from cold. I'm tempted to say it happens when the car is parked on a camber or slope but it hasn't happened often enough to really be able to connect the two. I'm thinking that in the first instance I'll replace the battery and see if that cures anything but should I be checking relays, fuses, fuel pumps anything 968 obvious before I embark on the long and painful process of identifying said intermittent fault through more elaborate explanation ?
Henry
Henry
