Jamesec
Looks like time for a new battery for my gen 2 997 Turbo S. I am trickle charging it so it is OK for now, but think I will need a replacement (trying to avoid the humiliation of a jump start at the local supermarket). Is this something I can get myself or would you recommend taking it to my OPC? I have heard things about not losing memory during the battery swap.
If this is a DIY job, any battery recommendations? I only do about 7k miles per year, which might be part of the problem.
Also, and sorry for the stupid questions....can I safely use the trickle charger (Porsche Charge O Mat) with a car cover on? I heard it needs ventilation but assume this means directly around the battery.
Many thanks in advance!
James
James
