idwoodvale
Was wondering if anyone else has ever had this problem......?
I've been using the car less than usual recently and it has sat for a week at a time in between each outing. The last two times when I have tried to start it there has been absolutely nothing in the battery. Not even enough to operate the central locking. After jump starting from the Volvo it runs fine and holds a charge for a short time afterwards. I had thought that I'd done something foolish when I recently installed the bass tube and new speakers..... but.... I think I found the problem yesterday.
The rear boot carpet with the foam pads covering the boot side pods - one containing the battery... has become rather wet due to the rear hatch seal failing. When I removed it yesterday I noticed that the underside of the pad over the battery was not only quite moist, but had two burn marks on it exactly where the battery terminals sit [
]. I'm assuming for now that this has been the cause of the problem and am going to see how things go with the carpet removed - seals to be replaced in due course.
I'd be interested in any opinions. Was there ever a cover for the battery in these cars?
